JD2210 upper driveshaft service/grease
   / JD2210 upper driveshaft service/grease #61
Hi Ovrszd,
I just bought a 2210 and I want to make sure the shaft is greased. So if I am reading correctly the front is easily accessible and if I cut a hole I can easily access the rear?
Once accessed just use a needle tip on my grease gun (sorry I am new to this and the 2210 is my first real tractor). Do you use polyurea grease on it or MOLY?
Egeezy. Yeah, if you get your hole cut, you should be able to access the zerk with a needle point. I always use the Moly grease.
But any grease is better then none at all. LOL! Later on about 6 months after I put the new spiders in, I noticed the back yoke was pretty sloppy on the transmission input shaft. I removed the yoke, turned it true on the lathe, and made a bushing to put on the back side of it so it fit tight around the input shaft of the transmission. I made it so it stuck out about 5/8" beyond the yoke. I didn't put any spline it in, I just made it to fit snug around the transmission shaft. Made world of difference. I did have to press the spider together with the driveshaft in the tractor. But, I'm pretty well set now. Shouldn't have anymore trouble with it. Good luck!
   / JD2210 upper driveshaft service/grease #62
Can you show exactly where you cut the hole? Also, would you cut it in the same place again?
After you blow up your driveshaft and the front shaft of your trans. What will be a guess at price.
   / JD2210 upper driveshaft service/grease #63
??? Don't understand this comment/question. ??
No offense meant..
   / JD2210 upper driveshaft service/grease #64
No offense meant..
Question, My drive shaft broke u joints and the shaft at the front of the trans broke off looking for a price to get job done
Witnessed an owner pay his shop bill. $1650.
   / JD2210 upper driveshaft service/grease #66
Good for you! Gator has a good point, if the needle you are using is giving you some hard time, try one like I have on post 9. Also a hand pump grease gun works better then the lever style. One hand to hold the needle and the other for the pump. I had the lever one and always manage but once I got the hand pump it made it so much easier. So you are from Orlando, that explain the mower. Always exited here to get the snow but by February I sure envy you guys. :cool:
That's really funny, the other day I was working on the hinged doors on my barn replacing steel hinges and dropped a lag bolt, and it of course it bounced and rolled under the door edge, I thought. Inside the door in the hinge area looking on hands and knees when I can across my little screw on greasing needle....
"Oh, I've been looking for you for years". Unscrew the thick greasing zerk holder and the needle screws right on, I think 1985 to 1987 vintage from Napa Auto Parts. But this thing is stout, remembering why I needed it in the first place was greasing Chevy u joints, unless you want to pull them off the splines and grease them, not me.
   / JD2210 upper driveshaft service/grease #67
Where do get one today? I don’t have a Delorean to go back to 1987. LOL.
   / JD2210 upper driveshaft service/grease #68
I will have to do the same.
   / JD2210 upper driveshaft service/grease #69
Is there a chance that some 2004 JD 2210 were produced without a zerk fittings on the drive shaft. The manual does not mention them as a grease point and I have visually looked and have had my fingers all over the upper one and cannot locate it.
Mine was in the cross. No way you could have felt it with your finger. My replacement joints have zerks in the caps.
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
2022 Magni TH5 5.19P (A56435)
2022 Magni TH5...
