JD2210 500 Hour Maintenance
   / JD2210 500 Hour Maintenance #1
marq
Romeo MI
03 JD 2210
While awaiting spring I figured I'd look at what maintenance the compact tractor would need.
It states @500 hours to do a valve adjustment and "check fuel injectors".
The valve adjustment looks simple enough but the only item in the service manual for fuel injectors is a off engine test which has specialized equipment.
I haven't talked to dealership, so maybe it's something they can do, but is this a need to do or if tractor is running fine just leave alone?
   / JD2210 500 Hour Maintenance #2
I had the same question for my JD 5205 and the dealer's response: "if it ain't broke ........"
   / JD2210 500 Hour Maintenance #3
The most critical pending doom maintenance item on a 2210 is greasing the u-joints on the power shaft from engine to transaxle. Have you done that?
Mine has 900 hrs with no valve or injector maintenance.
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
