Oil & Fuel JD140 Fuel Leak
/ JD140 Fuel Leak #1
Anonymous Poster
Epic Contributor
I have a 74 JD140 that has fuel leaking out of the Carb. bore while it is not running.
Any ideas?
Thanks.
/ JD140 Fuel Leak #2
Sounds like the float and/or float needle is sticking. You might try some carb. cleaner additive. It could be the float is out of adjustment or the needle is worn but most likely the float sticking just enough to let fuel pass the needle when it's not running.
Billy
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
INSPECTION (A65563)
INSPECTION (A65563)
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
TRUCK RAMPS (A64556)
NEW, ATS Mini Excavator (A62679)
NEW, ATS Mini...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
