JD112
/ JD112 #1
nobody cares
2005 husquvarna
I have a jd 112( around a 1975 ) that has a hydralic lift. i had to put about a half pint of hyd. oil to fill the tank , still will not lift the snowblower. Anything else i should check to see why the hyd. are not working ??? Thnx Dave
/ JD112
Maybe you don't remember back in the day, People would come back with nobody cares. Just a old saying . Dave
/ JD112 #4
is it leaking oil? is the hydraulic cylinder working when you actuate the cylinder? is the drive belt slipping that goes from the engine to the pump?
/ JD112
Thnx for the reply. Got er fixed yesterday. Did a little tweeking , and whalla everything working. Hydralics and snowblower are working nicely. Snowblower is pretty loud. Maybe because of the chain drive auger. Will have to tweek on it a bit. Dave :thumbsup:
/ JD112 #6
take the chain cover off the RH side of the blower and make sure its tight. Shouldnt sag more than 1/2 inch or so. adjustment is on the RH side of the mount. Its on the shaft from the drive pulley. Give the shaft and the chain a couple shots of multipurpose grease.
/ JD112
Ok, thnx for the info. I'll check it out. Dave :tractor:
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
3012SFL (A61567)
3012SFL (A61567)
Volvo EC220EL (A60462)
2016 Nissan Altima Sedan. (A61574)
2016 Nissan Altima...
