JD1050 Warning Lights trouble
   / JD1050 Warning Lights trouble #1
garry
Ohio
JD 1050
The Warning Lights on my JD1050 do not work. By warning lights I mean Oil Pressure, Temperature, and Alternator. Since none of them have ever worked for me I thought it might be a common problem for all three. I have tried to read a schematic but am pretty much lost as to how to use it. Is there a common issue with JD1050 warning light? Would anyone have a suggestion as to where to start. Thanks.
   / JD1050 Warning Lights trouble #2
one contact on the bulbs have to go to power, and the other contact goes to the sensors, which gives the bulbs their grounds, and makes them light up when needed.. if you post the schematic, more help can be given..
   / JD1050 Warning Lights trouble #3
The little bulbs burn out. It takes a GE53 bulb
   / JD1050 Warning Lights trouble #6
Like everyone says, bulbs likely burned out. As an example your oil pressure light should come on when the key is turned on. It only goes out after the tractor is started and the engine has pressure. Same for the alternator if I remember right. I’m feeling too lazy to go check the book.
I feel very embarrassed. I went to test the bulbs and discovered the wire to the warning light console was disconnected. Now the Oil light and Charging light come on when the key is on. The temperature light still does not work. The bulb is good. The Temperature sender has one post. How do I test the sender? Thanks to all who encouraged me to check the bulbs.
   / JD1050 Warning Lights trouble #8
IF temperature indicator is just a light, its probably an thermal activated sender to turn on light.... IF you put a ground on the wire at the sender and lamp comes on, you will probably have to test the sender by removing it from block and heating it (pan of boiling water) and testing with ohm meter....Probably have to apply heat to sender to get it to close internal contacts if it is just a "snap" action off/on .... If it were a gauge to indicate temperature it probably would show change in resistance as sender heats up... A lot of how to test and what results will depend on design of sender....
Dale
   / JD1050 Warning Lights trouble #9
Just ground he wire at the sending unit. Light should come on when that wire is grounded. Those senders apretty cheap. If it’s old I would just put in a new sender after verifying the circuit is good.
I have a bad temperature sending unit and my other lights are working just find. What great advice from this forum. Thank you to everyone who chimed in.
2015 KENWORTH T800 (INOPERABLE) (A48992)
2015 KENWORTH T800...
2015 Dodge Ram 1500 Crew Cab Pickup Truck (A48081)
2015 Dodge Ram...
2015 INTERNATIONAL 4300 BOX TRUCK (A50046)
2015 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2014 RANCO ANVIL  EDQ 20-26 END DUMP (A48992)
2014 RANCO ANVIL...
New/Unused 10ft 18 Drawer Stainless Steel Workbench (A48837)
New/Unused 10ft 18...
