JD1010C basket case
   / JD1010C basket case #1
Duffy52
Erie, Pa
JD1010C
I have a JD1010C diesel and it is a basket case. The machine was converted from a generator to an alternator and all of the wires are hanging. The fuel system is also in disarray with many of the fuel lines broken and hanging. Does anyone have a picture the fuel system un-modified? I have been looking for a wiring schematic as well. HELP
   / JD1010C basket case #2
:welcome:
To the forum from Alabama.
   / JD1010C basket case #3
:welcome:
Here's the inj line parts schematic. I hope you realize that a 1010 diesel is one of the sorriest engines JD ever built. The engine blocks have a long history of cracking between the cyl liner holes. 1010/2010 diesels are prone to emit a lot of smoke upon initial start up.
   / JD1010C basket case #4
Does the alternator have a built in regulator or separate regulator?
I "assume" that the regulator is built in
Just two terminals
   / JD1010C basket case #8
With two terminals, large is output and goes to starter solenoid (same terminal as battery connects to). Small terminal needs 12v to start the alternator charging. Normally comes from key switch, a wire that is hot when the key is ON. It should have the alternator light in the circuit. 12v from key switch to alternator light, then to alternator. This light will NOT have a ground. Light will be ON when key is ON, and go OFF when the alternator starts charging. Think of it as battery voltage coming from the key to the light, and once the alternator starts to charge alternator voltage going back towards the light. The voltages cancel and light will go out.
You might want to have the alternator tested.
   / JD1010C basket case #9
Do your injection lines look something like this...
   / JD1010C basket case #10
skyhook
I don't what PC your schematic came from but it definitely wasn't from a 1010 PC because 1010 inj pump mounts vertical not horizontal.
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2011 Kia Soul Hatchback (A48082)
2011 Kia Soul...
2012 Buick Enclave Premium SUV (A50860)
2012 Buick Enclave...
