JD x758 Battery replacement
/ JD x758 Battery replacement #1
Oconee1868
JohnDeere 4200 & John Deere x758 2017 4wd
Any suggestions for a John Deere x 758 after market battery. The brand name dealer batteries are just too high $$$$ ??? Thanks
/ JD x758 Battery replacement #2
Plenty of options. If you do not know the battery group type, just measure your battery dimensions, CCA, terminal type and orientation, then look up what BCI group type will work in your machine. Walmart, TSC, etc will likely have something that will work.
/ JD x758 Battery replacement #3
I have had good luck with Interstate brand batteries. They hold up much better than cheaper Walmart ones.
/ JD x758 Battery replacement #4
This is years ago. My brother in laws JD 748 needed a new battery. He took the old battery to an automotive parts store. They supposedly matched it up. It would not fit. He had to go buy the JD battery. For some reason I remember the price. It was $148 then. It should be a lot more now.
/ JD x758 Battery replacement #5
/ JD x758 Battery replacement #7
I have had good luck with Costco batteries. I got the JD when I replaced mine because I couldn't find a group 51 costco only had the 51R. My factory battery only lasted 5 years so we will see how long this one lasts. It's starting its third season.
If you use it during the winter don't skimp on the CCA but if you use it only during the summer it probably won't matter.
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2022 EZ-GO ELITE...
Cast Iron Anvil (A61574)
Cast Iron Anvil...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
