JD X749 Diesel keeps dying out while cutting.
/ JD X749 Diesel keeps dying out while cutting.
The oil cooler was plugged on mine and after the oil cooler the radiator was getting plugged. I had to unclip the trans cooler and pull it out of the way to clean it.
If I recall the temp was high but still workable but the tractor mower deck would have to be reengaged after every reverse direction. Yours is newer so they probably put more features on it.
Don't know if you read an earlier post but this was my problem. You were one of the earlier people to suggest this, but I was thinking about the outer screens and forgot about the inner one. As for the oil cooler, everything is super clean there, just grass clippings stuck to that screen. And you are right, my temp was what I thought very acceptable, but JD must know better. Thanks again!
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2020 Vermeer Vac-Tron LP873SDT T/A Vacuum Trailer (A59228)
2020 Vermeer...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2021 Polaris Ranger 570 EFI AWD Gas Utility Cart (A59228)
2021 Polaris...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
