JD x585 will not start
/ JD x585 will not start #1
Havoctec
Minnesota
John Deere 4310
It turns over but does not fire. Took off the air filter poured in a small amount of fuel and the engine runs for for a second or so until fue is gone. I hear the fuel pump when turning on the key so i pulled the fuel line off at the bottom of the fuel filter and turned ovee the engine. No fuel came out of the line is that normal?
I also loosened the presure relief screw and I can here fuel pouring into the tank. Is it posible that the fuel line diconected from the pump and is just circulating the fuel in the tank?
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2009 International 7400 Crane Truck, VIN # 1HTWGAAR39J160604 (A65563)
2009 International...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
7in. Auger Bit (A65640)
7in. Auger Bit...
