JD Verical Exhaust WARNING!
   / JD Verical Exhaust WARNING! #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
For anyone that installed the vertical exhaust on their 3x20 or 4x20 tractors. You may want to check your exhaust and take steps to prevent the problem I had. Mine has been idle for awhile and when I went to remove the exhaust stack to open the hood I just could not get it off. Pulled and pulled. Rusted in place. I tried to use a block of wood to knock it upward to loosen it. Didn't work. So, I ended up using a piece of wood lath about 20 inches long to go up under the hood from below and tapping it with a hammer. That worked.
Of course the exhaust being stuck on set off a whole disassembly of the system,cleaning and painting with black heat resistant paint. I also never siezed the inside of the exhaust stack and the tappered pipe it sits on.
   / JD Verical Exhaust WARNING! #2
Never siezed usually does the job in preventing things like that happening.Good luck .Mike
   / JD Verical Exhaust WARNING! #3
I appreciate the heads-up. I just installed the vertical exhaust on my 3320.
   / JD Verical Exhaust WARNING! #4
Good lesson to be learned here...use an anti-seize on all exhaust fasteners if you ever want to remove them!
And yeah, I learned the hard way too!
   / JD Verical Exhaust WARNING! #5
One thing I do that helps here is, when I'm going to be down for a bit, I hook up a battery tender. This requires opening the hood - which requires popping off the vertical stack. I will add the never-seize though. Great idea!
   / JD Verical Exhaust WARNING! #6
I sure wish they made a verical exhaust for the 2520. Seems like I can always smell the diesel.
FRONT MOUNT POLY TANK W/ MOUNT (A52708)
FRONT MOUNT POLY...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
1742 (A58374)
1742 (A58374)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
John Deere 1025R (A53317)
John Deere 1025R...
