JD Verical Exhaust WARNING!
   / JD Verical Exhaust WARNING! #1
dirtworksequip
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
For anyone that installed the vertical exhaust on their 3x20 or 4x20 tractors. You may want to check your exhaust and take steps to prevent the problem I had. Mine has been idle for awhile and when I went to remove the exhaust stack to open the hood I just could not get it off. Pulled and pulled. Rusted in place. I tried to use a block of wood to knock it upward to loosen it. Didn't work. So, I ended up using a piece of wood lath about 20 inches long to go up under the hood from below and tapping it with a hammer. That worked.
Of course the exhaust being stuck on set off a whole disassembly of the system,cleaning and painting with black heat resistant paint. I also never siezed the inside of the exhaust stack and the tappered pipe it sits on.
   / JD Verical Exhaust WARNING! #2
Never siezed usually does the job in preventing things like that happening.Good luck .Mike
   / JD Verical Exhaust WARNING! #3
I appreciate the heads-up. I just installed the vertical exhaust on my 3320.
   / JD Verical Exhaust WARNING! #4
Good lesson to be learned here...use an anti-seize on all exhaust fasteners if you ever want to remove them!
And yeah, I learned the hard way too!
   / JD Verical Exhaust WARNING! #5
One thing I do that helps here is, when I'm going to be down for a bit, I hook up a battery tender. This requires opening the hood - which requires popping off the vertical stack. I will add the never-seize though. Great idea!
   / JD Verical Exhaust WARNING! #6
I sure wish they made a verical exhaust for the 2520. Seems like I can always smell the diesel.
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A55973)
2015 Freightliner...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
