JD subcomp troubles
/ JD subcomp troubles #1
ajm11
its a 20+ yr old jd 7200. i came to it in maine sitting in the barn under regular use untiol it gets cold. got told by owner its a "bear to start in the cold" has glowplugs but wont start under 40 degrees. Now knowing the owner the plugs prolly have never been changed the plugs. so he uses ether in a short burst to get it going. but when u crank it over it grind and clanks on the starter. whats going on and what should i do before the tractor dies.
/ JD subcomp troubles #2
You are describing the symptons of glow plugs not working. Either burned out or the feeder wiring, relays, or connections are shot.
Don't use the ether, you are headed to a piston or connecting rod failure.
VOLVO A25D Cab (A68134)
VOLVO A25D Cab...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
1988 Yamaha 200hp 2-Stroke Boat Motor (A66738)
1988 Yamaha 200hp...
2021 John Deere 4044M (A64126)
2021 John Deere...
