JD SCV hydralics only goes one direction
/ JD SCV hydralics only goes one direction #1
farmerracing
Hello -
I have a JD 5105 tractor with two SCV's (used for loader, etc). The levers only go down, and do not lift up. They will center, and float. The 3PT hitch works fine up and down. This is not isolated to the loader, as attachments (haybine, baler) all work the same way. Reversing the attachment hoses does not change the lever behavior. (lever still only goes down, implement goes up) ---
About six months ago the first lever did this, (the second worked fine) and now both are doing this.
Any ideas?
/ JD SCV hydralics only goes one direction #2
Not sure on the JD but most control valves will have a return spring in the other end have seen a lot of the bolts back out and not let the spool move correctly pull the end cap of the valve and ckeck that just be carefull with the one with the float you don't loose thr balls for the detent
2002 BMW 325Cic Convertible Coupe (A61569)
2002 BMW 325Cic...
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
2019 Ford F350 (A61568)
2019 Ford F350...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Pinnacle...
2014 Nissan Altima Sedan (A61569)
2014 Nissan Altima...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
