spitter
Platinum Member
Hello. I have a tc45d tractor and I was using it today all morning. I lowered the 3 point hitch, got off the tractor to move something, then got back on and the hitch will not go up. I looked at the contol lever and it is hooked up and moving. I checked the oil level and it was good. everything else works just fine. I removed the attachment that was on the hitch and you can see it tries to move but will not. It does not matter if anything else on the tractor is operated at the same time. I removed the lower control valve and the pressure relief valve on the cylinder head. Tried moving the lever up and down. There is no fluid coming into the 3 point cylinder. Also i had replaced the hydraulic oil and filters a few months ago
