JD "polyurea" grease improved my bucket loader function---FYI
   / JD "polyurea" grease improved my bucket loader function---FYI #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a small JD790 TLB and, while it only has 225 hours on it the bucket slops around on opening and closing and sounds loose when it's not. Normally I use plain old moly or moly-lithium grease. Anyway, I gabbed the wrong grease gun the other day and greased the loader with JD "polyurea" grease. It's much thicker than what I had been using and to my surprise--maybe shock--it took up all the "slop" and all of the noise associated with it. I asked my parts guy and he said it's often the grease of choice among construction people.
So a few days after the fact and after a few hours of gravel use the loader sounds like I just greased it. Tight and with no noise or sloppy sounds. Here's the grease--and all JD greases for that matter.
John Deere Grease JohnDeere.com
For what it's worth, that's what I discovered and just passing along to the TBN people. Just an FYI.
   / JD "polyurea" grease improved my bucket loader function---FYI #2
Thanks for the tip. I will give it a try. I'm a believer in JD grease since my experience with their corn head grease in my Case's drivemotor with a blown seal. It ran cooler than the other side filled with gear oil. I also use it in the gear box of my brush hog.
The bucket fittings is where I noticed the difference. The grease is really thick and seems to stay that way.
   / JD "polyurea" grease improved my bucket loader function---FYI #4
Wonder if it penetrates enough to provide adequate long term lubrication?
I don't see why it wouldn't. It's rated for it. If anything, I'll bet its extra tacky nature gives better lubrication. The lube interval is10 hours.
Plus, now that I think about it I'm pretty sure it's the grease of choice mentioned in the loader owner's manual.
   / JD "polyurea" grease improved my bucket loader function---FYI #6
I won't claim any miracles, but I've been using the JD polyurea greases for 10+ years in just about everything I own and its served me well.
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
jet ski trailer (A56859)
jet ski trailer...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
