JD "polyurea" grease improved my bucket loader function---FYI
   / JD "polyurea" grease improved my bucket loader function---FYI #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a small JD790 TLB and, while it only has 225 hours on it the bucket slops around on opening and closing and sounds loose when it's not. Normally I use plain old moly or moly-lithium grease. Anyway, I gabbed the wrong grease gun the other day and greased the loader with JD "polyurea" grease. It's much thicker than what I had been using and to my surprise--maybe shock--it took up all the "slop" and all of the noise associated with it. I asked my parts guy and he said it's often the grease of choice among construction people.
So a few days after the fact and after a few hours of gravel use the loader sounds like I just greased it. Tight and with no noise or sloppy sounds. Here's the grease--and all JD greases for that matter.
John Deere Grease JohnDeere.com
For what it's worth, that's what I discovered and just passing along to the TBN people. Just an FYI.
   / JD "polyurea" grease improved my bucket loader function---FYI #2
Thanks for the tip. I will give it a try. I'm a believer in JD grease since my experience with their corn head grease in my Case's drivemotor with a blown seal. It ran cooler than the other side filled with gear oil. I also use it in the gear box of my brush hog.
The bucket fittings is where I noticed the difference. The grease is really thick and seems to stay that way.
   / JD "polyurea" grease improved my bucket loader function---FYI #4
Wonder if it penetrates enough to provide adequate long term lubrication?
I don't see why it wouldn't. It's rated for it. If anything, I'll bet its extra tacky nature gives better lubrication. The lube interval is10 hours.
Plus, now that I think about it I'm pretty sure it's the grease of choice mentioned in the loader owner's manual.
   / JD "polyurea" grease improved my bucket loader function---FYI #6
I won't claim any miracles, but I've been using the JD polyurea greases for 10+ years in just about everything I own and its served me well.
2019 Chevy Cruze (A56859)
2019 Chevy Cruze...
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
JCB 8029 CTS EXCAVATOR (A52709)
JCB 8029 CTS...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2006 GMC C5500 BUCKET /SIGN TRUCK (A58018)
2006 GMC C5500...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
