JD Parking Brake Light Coming On
   / JD Parking Brake Light Coming On #1
TebowGator
John Deere 4410
Anyone experienced the JD 4410 Parking Brake Light coming on and staying on? When starting to drive, after releasing the lever-release, the light will stay on and I have to continually tap the pedal to release it. It will continue to come on and I have to tap the brake to release. Any ideas how to resolve?:confused:
   / JD Parking Brake Light Coming On #2
Remove the cowl where you insert the ignition key, you will need to adjust the park brake switch here. It is a plunger type switch that when it is dirty, corroded or out of adjustment will not fully operate. Also i had some issue of the park brake linkage not fully releasing in or near the same location. If i recall it is a toothed rounded bar that when the park brake lever is pulled the teeth on the rounded bar engage the lever. It will require some lube on the hinge point of this "toothed rounded bar". It will all make sense wken the panel is removed. I had the same issue with both the 4310's i have owned.
CED, thank you for your prompt and helpful response. I appreciate you taking the time to reply to me. It is very annoying to have that light coming on. I will try what you say. THANKS!
   / JD Parking Brake Light Coming On #4
On my 4310, if it does that I reset the brakes and release them again. It must have the sticking plunger as talked about before. Usually if the light is on it seems on mine the rt brake linkage is sticking.
mfreund, thank your for your reply and input; it is most appreciated.
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
