JD Pallet forks
   / JD Pallet forks #1
rjgogo
North Central Illinois
JD2305
I found a set of used pallet forks with quick attach and I am wondering if they will fit on my CX200 loader. I kind of doubt it but i figured I would check to see if I am wrong.
I looked all over the JD site and could not find an answer. They were last on a 4520 which is a larger CUT I think. Anybody know for sure?
   / JD Pallet forks #2
rj,
I'm not sure, but I thought I saw on pics that the JD forks had two sets of pins to work with different size loaders.
   / JD Pallet forks #3
The QA points are the same for the 200x and 300x series loaders, as well as the older 410,420 and 430 loaders.
The new Frontier forks have 2 sets of lower pins so they can be used on the 200x, 300x and 400x, as well as the older loaders.
   / JD Pallet forks
Thanks, just to be sure I will get the pin measurement. I knew you all would be able to help
   / JD Pallet forks #5
Here is a picture of my Horst forks which has 2 pins on each side. It is mounted on my 300 loader. I have been told the upper pins are for the 200 and 300 series loaders and lower pins are for the larger 400 series loaders.
   / JD Pallet forks #6
kennyd -
So, if the 200cx and 300x loaders have the same pins, can I put the snow plow blade from JD on my 200cx?
I seem to remember JD offering a snow plow for the FEL on a 300x... I know they do for the 300cx. But there's no listing for a snow plow for 200cx.
   / JD Pallet forks #7
Last fall, I saw a very nice snow blade mounted to the JD pin hitch on a 2305. It was a six foot blade I think, and was painted gray, so I don't think it was a JD blade. It was well built, and didn't stick out there a mile, and it sure was on a 200cx loader. Wish now that I had taken a picture of it. Curtis also makes one for that loader.
   / JD Pallet forks #8
The Curtis is very nice and very expensive. I just can't justify the expense... but also figure by the time I find a 6' rusty old blade and pay the fabrication shop to weld up attachments to the loader, I'll be pretty close in price to factory. Well, maybe not quite that expensive, but if I were to resell, a Curtis or JD would be worth a lot more. Thanks.
   / JD Pallet forks #9
Here is another really slick, and well executed solution. This install retains the advantages of having some float in a plow blade..... something else to consider...
   / JD Pallet forks #10
bxowner said:
kennyd -
Yes, it would fit...BUT
I built a blade for my loader a few years ago from a Meyers Poly-Plow, and while it did work, my tractor was just to light. I had trouble steering, and even going straight was a challenge. I just do not think the FEL plows are effective on the small frame CUT's. It also makes the whole unit so long that maneuverability becomes a problem in small spaces.
I have since found an older #380 frame mounted blade that I modified to fit and the difference is like night and day!
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
John Deere 4 Row Corn Head (A50775)
John Deere 4 Row...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
Horse Weathervane (A55758)
Horse Weathervane...
2011 MACK CHU (PINNACLE) (A55745)
2011 MACK CHU...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A55788)
2015 Ram 3500 4x4...
