JD Model 790
/ JD Model 790 #1
riseandgrind
Ca
None Yet
Have an opportunity to upgrade to a JD Model 790 2001
Has 303 Hrs and includes a Model 70 Loades, Brush Hog and Auger
Garage Kept, 1 owner. In great Shape
10k seem reasonable? I see them listed from 11500 to 13k without any attachments?
It's also a Manual Gear Box, don't think that model came with HST
Any opinions?
/ JD Model 790 #2
I gave $11,5000 for my '04 790 5-6 years ago with 300 loader (quick-tach) & 5' Woods finish mower, 385 hours. It's been well worth it to me!
/ JD Model 790 #3
Can't help with price but I bought mine new, it's a couple years older than what you are looking at. Similar hours and equipment. Been a solid tractor! And you are correct, no HST on the 790.
/ JD Model 790 #4
Any opinions?
That doesn't sound like too bad a deal. Have you looked at new small tractors for sale at dealers near you? You'll of course spend more but get a 15 yr. newer machine with warranty and good financing if you need that. We went through the used vs. new decision a few years ago (2014) on a smaller tractor than the 790, and decided on new, which actually wasn't that much more than the used prices we saw on same size machines on the market then, and got HST, 5 yr. warranty and low rate financing. Good luck with what ever way you go!
/ JD Model 790 #5
Buy it, that is a good price with the loader and hours. I have one and it has been a great tractor. You are right they are gear only.
/ JD Model 790 #6
The 790 is a great little tractor. Those early models were advertised to have 30 engine HP, but I understand that was a bit exaggerated. More like 27 engine HP and 24 PTO HP.
They'll handle a 5' rotary cutter pretty easily and a 6' rear finish mower.
The tractors are a bit on the light side...about 2200 lbs without the loader. I expect the #70 loader would add about 700 lbs.
The gear box is what is referred to as a collar shift...not only is it a manual box, it's not synchronized with high/low ranges (total 8 speeds forward, 2 reverse). However, there's not much need for shifting...select the gear you need and go. You'll likely get some responses stating loader work is much easier with a hydro transmission...probably is, but you'd only be adding a few seconds to change direction.
The tractor should have a two-stage clutch (push halfway down to shift gears, all the way down to disengage the PTO. That takes a bit of getting used to and you DO NOT want to ride the clutch!
I had a 790 for 6 years and I really liked it...except:
Reverse low is really slow, even at PTO speed. Reverse high range is too fast (again, at PTO speed). That's the only reason I traded the 790 in...
One more thing...during the first 8-10 years of production, there were three engines (all Yanmars) used in the 790. If you go for a service manual, make sure you have the serial number of the tractor (it's on a plate just above the rear PTO guard.
/ JD Model 790 #7
That's not a bad deal at all. If you are in the market for a tractor that size, and don't mind gear shift, go for it. What Roy had to say is important though. My Ford 1715 has High, Mid, and Low ranges, and I'm sure glad it does! I mostly keep mine in mid range, and use 2nd, and reverse for just about all loader work. It makes for a good easy shifts, with loads of torque.
Chris
/ JD Model 790
Thanks for all the replies everyone. I am actually really happy with my Iseki - I was contemplating buying this tractor and flipping it. I just get a little nervous dropping 10k I think its worth more out here in my market!
/ JD Model 790 #9
If you're looking for a flip, I don't think you'll make a ton on it, but could possibly make a couple grand if you wait long enough, and it's in the right condition. The hours are very low!
Chris
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
KUBOTA 60" PIN ON BUCKET (A64280)
KUBOTA 60" PIN ON...
LMC Ag 3pt 100 Gal Mist Sprayer (A64119)
LMC Ag 3pt 100 Gal...
