JD Mid-Mount Mowers Maintenance
/ JD Mid-Mount Mowers Maintenance #1
KTD
NE PA
JD 4310 e-hydro
When my new 60" MMM was delivered, the service tech pointed to the knobs holding the belt shields. "Be sure and put some penetrating oil on each knob. Rust on those knobs is a MAJOR item in mower maintenance in the shop."
Well, since the mower is stored indoors I thought that it would ok to wait until I had a few minutes free. A month later I got around to checking out the mower. When I tried to remover the belt shields, I found that the knobs and shafts were quite rusted.
Maybe you want to check yours and get some oil on those knobs.
/ JD Mid-Mount Mowers Maintenance #2
Too bad the service tech didn't just put some grease on each one before delivery, but at least you were informed. Good tip.
Those shields are the first thing I remove on my new deck. They only serve to attract and hold water/moisture, and keep me from blowing the deck clean after each use. An occasional stick might get tossed up on the deck and it throws the belt (once in 150 hours), but they are for no other use, IMO.
Maybe some desk jockey thinks they are for safety, but no hands or feet are around the belt when the mower is operating so I don't buy that theory.
I like them off. /forums/images/graemlins/grin.gif
/ JD Mid-Mount Mowers Maintenance #3
First time I pulled the belt shields on my 7-Iron deck I noticed the knobs were difficult to loosen, so when I reinstalled them I greased the threads. About every 25 hours of mowing time I pull the shields, blast out the grass clippings with an electric blower, then use a power washer to remove the remainder of the debris.
Whenever I do a lot of loader work (digging and grading) I always pull the belt shields and clean underneath before using the MMM again. My turf tires throw a lot of dirt and gravel onto the deck and despite the shields some of the grit works underneath. I'm sure the debris would accelerate belt wear if I didn't clean it out, so....maybe I should just leave the shields off as you do.
/ JD Mid-Mount Mowers Maintenance #4
Are these the metal shields that cover the outboard blade spindle pulleys? My 60" deck is 6 years old or so. The panels on mine have latches to hold them in place. Don't know if that is an older style...must be. Placing the panels with the latch system is sometimes a minor nusiance if alignment isn't just right, but no threads to rust.
OkieG
/ JD Mid-Mount Mowers Maintenance #5
Yep the older 60" mid mounts come with the latch type metal covers. They were made up until 2000 about then the 60" 7 iron deck came out with plastic shields.
In my opinion the metal shields are much easier to remove. I have had both and still have the 970 with the old style 72''. The 7 iron has so many clips on the shields and the 2 stubborn knobs that are a pain to reah under the center of the tractor.
/ JD Mid-Mount Mowers Maintenance #7
Is it a 7 iron? Green or yellow deck? I did not think they made those anymore. When I ordered my 4300 new from the factory late 2001 my boss said I might get lucky and get one of the new green decks. My JD before that had the normal 60'' deck non 7 iron. I know you can still get the 72'' with metal covers as it has been for a long time. The 54 and 60'' cuts have plastic.
/ JD Mid-Mount Mowers Maintenance #8
The belt covers for my new 60" for my 4110 also use latches on the front with nuts on the back. The 4110 cannot be fitted with the 7-Iron--not sure why. This is the standard 60" HD deck. It's green.
APPROX (12) 8" & 10" I BEAM UP TO 12' (A64280)
APPROX (12) 8" &...
2005 TerraGator 8104 (A63688)
2005 TerraGator...
60" PIN ON EXCAVATOR RAKE (A64279)
60" PIN ON...
2022 Mercury Verdado 300HP Outboard Boat Motor (A61574)
2022 Mercury...
2016 KUBOTA RTV-X900 UTV (A64280)
2016 KUBOTA...
2012 Ford Expedition SUV (A61574)
2012 Ford...
