JD M665
/ JD M665 #1
Rickcooksey
Williston tn
M665 z turn
I have a JD M665 Z turn
The right drive wheel reverse speed is slower than the forward speed. What could cause this?
/ JD M665 #2
:welcome:
And you suspect this because the handles are not across from each other when going in reverse?
Or something else?
Seem okay going forward?
/ JD M665
Yes I have suspected it for some time because of the inconsistance in the steering. I jacked it off the ground and could tell then the speeds were different.
/ JD M665 #4
I believe there are adjustments to fine tune the handle position and the hyd. motor speeds.
Either the Deere dealer can do for you, or get the tech manual if figuring on doing your own work.
Or, if a member here has the procedure and will share it.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 Dodge Ram 5500 (A64127)
2016 Dodge Ram...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
