JD/Kubota/Kioti
/ JD/Kubota/Kioti #21
The DK4510 and larger is not available with a hydrostatic transmission, but is available with a standard synchro tranny which will require clutching or a hydraulic shuttle which does not require clutching. The DK4510 is missing a few things. most notably telescoping lower links and telescoping stabilizers.. However that can be fixed with the addition of a good quick hitch and hydraulic top and tilt. The 4wd is actuated by mechanical lever instead of electric/hydraulic switch, but that may be good or bad depending on your opinion.
