John D
I have been given the use of a 6ft aer-way and got it home and its about 1 1/2 inches not being wide enough to fit the Imatch. is there a longer pin I can get or do I have to custom build something. jb
Junk the Deere I-Match. Go purchase a Speeco quick hitch for $100 or a Farm Pro quick hitch for $70. They work on everything and the I-Match works only on 5% of implements.John D said:I have been given the use of a 6ft aer-way and got it home and its about 1 1/2 inches not being wide enough to fit the Imatch. is there a longer pin I can get or do I have to custom build something. jb
Rant on:CCI said:Junk the Deere I-Match. Go purchase a Speeco quick hitch for $100 or a Farm Pro quick hitch for $70. They work on everything and the I-Match works only on 5% of implements.
_M_ said:It's also possible that simply installing the JD bushing kit on the impliment would increase the pin width enough to use the i-match hitch. The kit is about $30 and is not a permanent modification. I'd say it might just add 1.5" - 2.5" of width for the i-match to grab onto. Do a search for the bushing kit and you should be able to find the part #. I'm not sure what it is.
diyDave said:What size tractor are you trying to pull the aerway with? You need at lease 40-45 hp to pull this implement with (at full penetration), so the size of the hitch is moot if your tractor is too small for the implement.
John D said:Thanks guys. I have a JD 5103 50 hp. will pull it just fine. the aerway has the bolt through pins on it but are about 1 1/2 inches to short on each side to match up. my first thought was longer bolt throughs but was thinking the may bend being too long? maybe a pc of soid round stock all the way through and welded the the supports. sorry about the respond time but I when fishin?? jb
