JD Hydro Top link or Other
   / JD Hydro Top link or Other #11
nmu98 said:
I just have to figure out the legnth. The 18 to 26.5 or 20 to 32...
An important factor is if you use Pat's EZ Hitch. If so, estimate high. In general it's best to take a look at where your toplink is actually set with your implements (and don't forget the install process, I've got a few implements that need to be shortened to install) rather than the real toplink length, but exchanging toplinks is fairly easy so if you end up with one of each size it's not the end of the world.
I use the Imatch.
Mine hangs out at about 24 most of the time. Thats whay I have an issue. Do I go for one that only goes 2.5 inches past where I normally am... Or go witht he one that is 6 inches past 24, but only 3 shorter. it seems to me that shorter would be more useful?
   / JD Hydro Top link or Other #13
How do you use your implements? I can see a rotary cutter wanting a shorter toplink to angle it up, that may allow you to back into tall brush a bit more cleanly (but it's also a bit on the dangerous side). A backblade may be better off with a longer link to angle it for more bite. A rear blade or a disc/plow may have other needs. Most of the implements you listed are generally best left level, so a hydraulic toplink may not be all that useful for them since you've got iMatch working (but that doesn't mean it's not a fun toy!).
   / JD Hydro Top link or Other #14
nmu98 said:
I was drastically mislead by my dealer. I called back to get a part number and i was told this hydro top link was not a Deere kit. Evidently Deere wants 600 dollars to part out what you would need. The kit he wanted to sell me is a gannon, or tifco. Part # TLH01.
Needless to say I am going to call CCM...
I thought the price for the JD cylinder was cheap. You will not regret getting the CCM one.
   / JD Hydro Top link or Other #15
nmu98 said:
I use the Imatch.
I'd be cautious about going too long unless you ever plan to install a Pat's system or other quick hitch. I found on a previous hydraulic toplink that I could extend it so far that my boxblade's bottom would rotate far enough forward to hit my tires. I think I'd opt for the 18 to 26.5 length.
The CCM toplink is rock solid, not spongy whatsoever. I really like mine. I had one before that was from bailey.net with 1/2" hoses. It had almost a full inch of spongy play and it made a big difference in using my boxblade. Anything bigger than 1/4" hoses is a waste. I even have a 0.031" restrictor orifice in mine to give me very fine control. Also, I don't know how you could get a neater install than the one from CCM. I have 36" hoses on my NH TC45D and they are perfect. The only way it could look neater on your tractor is if you paint it JD green.;)
   / JD Hydro Top link or Other #16
The cylinder itself is great (although I prefer black to JD green - anything but the baby blue it came in ;) ), but if there was a JD kit for my rear SCV addition it would look a lot prettier than my oversized Prince valve setup (not supplied from CCM). If available my choice would be a CCM toplink but a JD rear SCV setup.
Fully agree on the "rock solid" description, you'd never know it was hydraulic until you need adjust it.
Thanks for all the advice. I am going to order tomarrow after 1:30 when the guy gets in. My tiller would be nice to adjust, but very little. I would love to use this to be able to lift the rotary cutter off the ground farther for travel or cleaning. I think the suggestion of the 18 to 26.5 wis probably correct. I am going to go out and adjust mine to those and see the angles of the imatch.
I rarely use the back blade, but I do use my disc, but that is ussually level.
Anyone with a 3x20 have a ccm? What one?
Thanks for all the insight.
BTW, do the Pioneer QD's work on the JD rear SCV's?
   / JD Hydro Top link or Other #18
In case it helps, here's a post on my installation adventure including part numbers. If you mean the Power Beyond port then the 2520 has Parker fittings. If you mean a rear SCV connection then the 2520 uses Pioneer fittings but the Buyers fittings that Northern Tool sells work fine. Of course, the 3x20 tractors (or even tractors from other dealers/sales dates) may use different fittings.
Thanks for the link. I was out tonight and ran my rotary cutter at 26.5. It was as far back as I would go with that. Would have been nice to be able to pic it up off the ground when lifted......
Still don't know what one to buy..... 20 to 28 would have me sold.... or 19 to 29.... Dunno...
   / JD Hydro Top link or Other #20
Are you guys using your 3rd SCV, or the diverter valve kit to run the top link?? Just wondering, incase I ever wanted to use a hydraulic angle on a blade, rake, or blower. The diverter kit is pretty expensive, just wondering your opinions on if it's worth it. Would the Top link drift down enough during regular use to be a problem ?? - ie. if I had the blower on the back and switched the diverter switch to run the FEL, would the blower sag???
-J.
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
Club Car Electric Cart (A55758)
Club Car Electric...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
UNUSED FUTURE 32" PIN ON RAKE (A54757)
UNUSED FUTURE 32"...
TAG General Purpose Bucket Loader Attachment (A55787)
TAG General...
