JD Hay Moisture Tester question
/ JD Hay Moisture Tester question #1
Hay Pirate
Orange County, NY
I have a SW16136 JD Hay Moisture tester. The wrong guys have been using it around here and ripped the wire off at the connector. All I need to do is resolder the wires onto the connector, I just need to know which wires go where.
Anyone have this model to post a pic of where the wires go? Or just tell me which number has which color. There are 4 wires, white, black, green and yellow.
Thanks.
/ JD Hay Moisture Tester question #3
Not sure of the JD testers but we bought a new farmex that uses the same plugs as a 4 pin CB radio microphone and went wrong in the first week..?
/ JD Hay Moisture Tester question #4
I just worked on one of these tonight, same problem.
Pin 1- Black
Pin 2 - Green
Pin 3 - White
Pin 4 - Yellow
I would add a layer of heat shrink tubing where the connector strain relief clamp tightens to minimize future slippage and pull-out. Also, apply a small amount of service removable small thread Loctite to the clamp screws.
(1) 50"x81" TAILGATE (A60430)
(1) 50"x81"...
Club Car Utility Cart (A55851)
Club Car Utility...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
