JD GT275 Won't Start
/ JD GT275 Won't Start #1
adawg88
I have a Kawasaki 17HP John Deere GT275. This thing has never given me a second of trouble until this weekend -- it won't start.
It has been 3 weeks since I fired it up and mowed the grass, so I went out there Saturday and it won't start. It turned over, started to start, backfired then wouldn't try to start again (although would turn over). I replaced the spark plug on a whim and it tried to start again, a small backfire and some black fumes came out, then wouldn't even try to start (although it would turn over) again.
Any idea what could be going on? I need to get this fixed before my neighbors start complaining about my grass.
Many thanks!!
/ JD GT275 Won't Start #2
I'd try another new plug and a shot of starting fluid. Welcome to the forum. Jake
So for kicks I yanked the new plug to check for spark -- at least I have that going for me. I do have spark.
/ JD GT275 Won't Start #4
My brother has the same mower. He has had to put a fuel pump on his for the same non starting problems. Also may just need new fuel lines. JC
So should I pull the fuel lines to check that? I am totally new to all this so I will likely ask a lot of stupid questions.
Thanks!
/ JD GT275 Won't Start #6
How are the fuel and air filters. I have a F525 which has the same engine and one time it would not start till I replaced the fuel filter.
Chris
Chris
The air filter looks ok. I'm curious about the fuel filter. Should that whole housing be filled with fuel or just a small (maybe 1/2") of the housing under the paper filter?
I plan to replace it either way, but I've never paid attemtion to how much fuel was typically in the filter.
/ JD GT275 Won't Start #8
There should be no air in the fuel filter. Check your tank and lines for blockages and air leaks. Start at the tank, and work tour way to the carb. connection by connection.
/ JD GT275 Won't Start #9
Did someone turn the fuel shut off valve to close???
Any gas in the tank?
The gas tank is a little more than half full, but the fuel filter is most certainly not full, not even half full. Looks like I have a little more work to be done.
Where is the shut off valve on a GT275...any idea? Hopefully it is in the manual.
Thanks for the leads. I'll dig into this.
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A65056)
2014 CATERPILLAR...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2012 Mitsubishi Fuso FEC72S Box Truck (A66736)
2012 Mitsubishi...
