JD GT245 Road Speed ?
   / JD GT245 Road Speed ? #1
mauimayco
JohnDeere GT245
What else can I check to increase the road speed of my GT245? The belts are good and not sliping, the forward pedal moves all the way to the stopper.
Can the trans oil be old?
Thanks Denni
   / JD GT245 Road Speed ? #2
Rated speed on that little feller is about 7 mph. Any "road" time should be on a trailer.
Thanks, I read that the speed is 7 mph. My problem is its only moving about 3 mph. Its taking me twice as long to mow the lawn as it did 2 years ago.
   / JD GT245 Road Speed ? #4
:welcome:
When was the last tranny oil/filter change?
What filter? The oil was soposed to be changed on my last dealer sevice. I know if it wasnt. I requested an ABC service and was very disapponted. This is why I'm here asking ?
   / JD GT245 Road Speed ? #6
What does the manual say about transmission oil and filter change? Parts shows a couple filters in the tranny, but don't see how easy they are to change out when changing oil.
Has it been slowing down steadily, or some abrupt slow-down?
Slowing down steadily over the past year or two.
How do I Identify the transaxle? Is there a serial number or make stamped somewhere?
   / JD GT245 Road Speed ? #10
Sometimes the throttle cable can slip or stretch or something and need to be adjusted.
Chris
Toro Mower (A50324)
Toro Mower (A50324)
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
TRANSMISSION JACK (A53843)
TRANSMISSION JACK...
23018 (A53424)
23018 (A53424)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
