JD GATOR STARTING PROBLEM (KAWASAKI ENGINE)
   / JD GATOR STARTING PROBLEM (KAWASAKI ENGINE) #1
gpa311
Great State of Louisiana!
MTD Lawn Tractor (Breaks almost every time I use it!!)
Hello to all! I am a new member to this site.
I recently purchased a JD Gator HPX 4X4 Trail with the Kawasaki gas-burner. I am surprised with the difficulty in getting the Gator started (especially when cold).
I learned that I can hold out the choke and pat the gas pedal when starting her cold. I have to slowly release the choke and keep patting the pedal for a few minutes to get her warmed up.
I also noticed that even when she is warmed up, if I shut her down for more than about 10 minutes, she requires choking to get going again.
I can deal with quirks, but don't you think that for a >$10k vehicle, starting should be less hassle?
The Deere Dealer said "JD is aware there is a problem and are working on a remedy."
Can anyone out there give input on this issue? Any other starting "secrets?" Or, any word from JD on addressing this problem?
By the way, other than this problem, the HPX 4X4 is AWESOME!
Regards,
Greg
   / JD GATOR STARTING PROBLEM (KAWASAKI ENGINE) #2
My Gator starts great. I did have a friend that had the brand new Mule which has a similiar engine. His did not start very well at all. He took it back in and they worked on the jets in the carb. His starts great now.
Thanks for the quick reply!
I guess it's my luck to get one that is a bit difficult to start.
Actually, I can deal with it okay. It's my wife that is more impatient and more of a "get in it and take-off immediately" type of personality.....you know how that goes.....she's not interested in the mechanics of the vehicle.
But, it SHOULD be easier to start. I will inquire about the jet adjustment at my local JD Dealer.
I'm glad that yours starts okay, though. I HAVE made contact with a few people on the internet that DO have problems starting the Kawasaki engines. Maybe it is more common in the latest ones to roll of the assembly line, although I don't think anything has changed in the engine design lately, right?
Thanks again!
Greg
   / JD GATOR STARTING PROBLEM (KAWASAKI ENGINE) #4
I have the gator with the kawasaki engine, and mine is a bit on the cold side (not near as 'cold' as you described).
I am impressed with the engine and gator overall, and don't find the choking 'on-intitial-start' and some choke to 'get-going when in forward' to be annoying. However, unfamiliar drivers who never had to choke anything (i.e cars) can be a bit handicapped when trying to operate the gator until after the first 30-60 seconds it takes to warm it up.
The choke is in a very handy place (under the left hand cheek of drivers seat) but not intuitive if the 'new' driver doesn't know where it is or what to do with it if they find it. /forums/images/graemlins/grin.gif
Yes, this is the message I've tried to convey to my wife...it's not a car (although it costs as much). But, she is a "creature of convenience."
I will definitely show her your post. Perhaps it will give her some inspiration.
Thanks!
   / JD GATOR STARTING PROBLEM (KAWASAKI ENGINE) #6
I got a 98 Mule 550 and its been hard to start like yours every since I had it. No problems when its hot but if it sets 15 mins or longer look out. I use to just hold the pedal to the floor when it was cold and it would finally start but it seems if I pat the peddle some it starts faster. Close to 650 hrs on it now.
Thanks for the input Larry.
I'll be getting my HPX back today. I'll let you know if the throttle adjustment makes a difference in starting. The Service Guy at my JD Dealer said they can only increase the idle a VERY SMALL RPM. Too much increase would cause it to grind when engaging gears.
Has your original Starter Motor held up for the 650 hours, even with the extra time you must turn it over when cold?
GPA
   / JD GATOR STARTING PROBLEM (KAWASAKI ENGINE) #8
my 08 610 has been a brute to start since day 1. I finally opened the plug gap to .040", which is wider than the .032" spec. but it now starts like a dream. Almost instantly.
Big problem, small fix. gotta like it.
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
Cushman Electric Cart (A55851)
Cushman Electric...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
