JD gator 4 X 6 gas
   / JD gator 4 X 6 gas #1
mlinnane
Esperance, NY
mf 165
I went to go service my JD Gator 4 X 6 gas and I can not find the drain plug for the tranmission fluid. The gator is about a year old and I need to change the transmission fluid and can not find the drain plug. Any info would be helpful.
Thank you Michelle
   / JD gator 4 X 6 gas #2
Back the Gator onto a set of ramps, set the brake and block the front wheels. The drain plug is reached through a hole in the bellypan directly under the transmission. I think it takes a 16mm socket. Refill with John Deere HY-Tran fluid.
91013 (A48082)
91013 (A48082)
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
