JD gator 4 X 6 gas
   / JD gator 4 X 6 gas #1
mlinnane
Esperance, NY
mf 165
I went to go service my JD Gator 4 X 6 gas and I can not find the drain plug for the tranmission fluid. The gator is about a year old and I need to change the transmission fluid and can not find the drain plug. Any info would be helpful.
Thank you Michelle
   / JD gator 4 X 6 gas #2
Back the Gator onto a set of ramps, set the brake and block the front wheels. The drain plug is reached through a hole in the bellypan directly under the transmission. I think it takes a 16mm socket. Refill with John Deere HY-Tran fluid.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
