JD gator 4 X 6 gas
   / JD gator 4 X 6 gas #1
mlinnane
Esperance, NY
mf 165
I went to go service my JD Gator 4 X 6 gas and I can not find the drain plug for the tranmission fluid. The gator is about a year old and I need to change the transmission fluid and can not find the drain plug. Any info would be helpful.
Thank you Michelle
   / JD gator 4 X 6 gas #2
Back the Gator onto a set of ramps, set the brake and block the front wheels. The drain plug is reached through a hole in the bellypan directly under the transmission. I think it takes a 16mm socket. Refill with John Deere HY-Tran fluid.
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
Stone Concrete Trowel (A47384)
Stone Concrete...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
