JD Front wheel seal leak
   / JD Front wheel seal leak #1
nckennedy
Camillus, NY, USA
JD 5425
I have a JD 790 with a front wheel oil seal leak. Can I remove the whole wheel assembly and take it to a local dealer and have them change out the seal? Thank Craig
   / JD Front wheel seal leak #2
I have a PDF of the technical manual if you’d like to read up
On the repair, shoot me your email if wanted
Joe
   / JD Front wheel seal leak #3
We had same on our kubota. Put in some ATP AT-205 Re-Seal Stop leak over 2 years ago. So far, so good.
Could not find it in our local auto parts store. Ordered it from SummitRacing.com
I think we learned about it here on TractorByNet.
   / JD Front wheel seal leak #5
nckennedy, I believe if you are mechanically inclined enough to remove the front axle, you are competent enough to replace the seals yourself. Particularly with the help of the manual offered by joecdeere. I would also replace the seal on the other side while you were at it.
   / JD Front wheel seal leak #6
it's on the way
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
Land Honor Quick Attach Skid Steer Plate (A50515)
Land Honor Quick...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
