JD Differential Lock Upgrade??
   / JD Differential Lock Upgrade?? #1
GONO2
Bronze Member
South Central Virginia - GONO2 = Go # 2
JD 790
Is it possible to add the new differential lock to my 2002 GX335? Do they make an upgrade kit? /forums/images/graemlins/confused.gif
   / JD Differential Lock Upgrade?? #2
Check with the parts counter at your Deere dealer too. They should know right off the bat.
My suspicion would be they wouldn't. Just too expensive to offer, and I'd think the transmission would be too much an integral part of the picture to be 'either/or' for such an option to be added.
Good luck. /forums/images/graemlins/wink.gif
   / JD Differential Lock Upgrade?? #3
I doubt if JD would provide it but those GTs use trannys from the same mfg. (I bet I'm going to spell this wrong but I think it's "Kanzai") as a lot of other companies use. If you do some "googling" you'll find that sometimes there were optional versions of essentially the same oem diff used depending on final brand/model of tractor. You might find something that was done for someone other than JD if you investigate back through the oem but you'd be on your own as far as installation/repairs/making it work.
Or you could trade it in on an X-series. Depending on much you value your time it might be cheaper! /forums/images/graemlins/grin.gif
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
1994 Prevost Liberty Coach 40FT T/A Class A Motorhome (A51694)
1994 Prevost...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2016 Chevrolet Malibu Sedan (A51694)
2016 Chevrolet...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
