JD Brush Hog: Can’t access bolt to take blades off.
   / JD Brush Hog: Can’t access bolt to take blades off. #41
I've only sharpened blades once. That was many years ago. I cut a lot of brush, and with brush you want to shatter it (to weaken it- the idea is to reduce it's ability to grow back). The cut I get on grass, all things considered, is actually quite impressive.
IF you MUST sharpen then roll the cutter up against a tree (or support it raised) and braced and do that work (angle grinder).
The stump jumper on my 6-footer readily weighs more than I'm going to lift*: there's not only being able to lift, but being able to position it (as the blades want to swing all about). Couple years ago I had to deal with a detached stump jumper (actually had one fly out from under the mower!); flipped the cutter over and used the loader to hoist the stump jumper back on.
*I went out and rescued the stump jumper with my UTV (it was lost in the brush and I opted to take the tractor back home and fetch my wife and dog to help find the stupid thing). I towed/drug (ha ha, using the dog's leash) the detached stump jumper home behind the UTV- I wasn't going to try and lift it up into the bed of the UTV.
   / JD Brush Hog: Can’t access bolt to take blades off. #43
   / JD Brush Hog: Can’t access bolt to take blades off. #44
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2020 DRAGON ESP...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A58017)
2010 KENWORTH T660...
PALLET FORKS (A58214)
