jd baler miss tying
/ jd baler miss tying #1
tractorman14
My john deere 24ws wire tie baler is miss tying more than one should i know they miss ties every once in a while but it's missing more than it should is there anything i can do to fix this?
/ jd baler miss tying #2
Baler miss could be related to your other question about the loose bales. If the hay isn't being held in place it can make a baler miss. I would start with as was put out in the post clean out the baler and check your dogs and resistor plates. Then check your knife and even your feeder fork, is it pulling the charge of hay in too far or not far enough.
/ jd baler miss tying #3
Good advice.
What kind of hay.
You might need some additional hay resistors in addition to your hay holder plates. Stuck hay dogs also.
D.
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
AEREATOR (A58214)
AEREATOR (A58214)
Stainless Steel Commercial Combination Gas Flat Top and Stove (A60352)
Stainless Steel...
