jd baler miss tying
/ jd baler miss tying #1
tractorman14
My john deere 24ws wire tie baler is miss tying more than one should i know they miss ties every once in a while but it's missing more than it should is there anything i can do to fix this?
/ jd baler miss tying #2
Baler miss could be related to your other question about the loose bales. If the hay isn't being held in place it can make a baler miss. I would start with as was put out in the post clean out the baler and check your dogs and resistor plates. Then check your knife and even your feeder fork, is it pulling the charge of hay in too far or not far enough.
/ jd baler miss tying #3
Good advice.
What kind of hay.
You might need some additional hay resistors in addition to your hay holder plates. Stuck hay dogs also.
D.
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2021 Case SV280B (A62177)
2021 Case SV280B...
2023 Deere 325G (A60462)
2023 Deere 325G...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2018 Bell B30E 30 Ton Articulated Dump Truck (A60352)
2018 Bell B30E 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
