JD baler lube system question
/ JD baler lube system question #1
jimg
Is anyone familiar w/ the 'single point' lube (multilube) system the can be had on JD balers? From what I can tell it appears to be actuated by bales moving thru the case. Is that correct? What powers it? Is it truly single point or does it only grease certain subsystems leaving others to be manually greased? Is it trouble free (reliable)?
/ JD baler lube system question #2
Been a long time since I had one of these bailers. Memory could be faulty and design could have changed over the yrs.
Seem to recall mine was powered off the knoter mechanism. Don't recall it lubing anything more than the knoters.
/ JD baler lube system question #3
Used a JD 214WS baler when I was a kid. Ours was lubed manually by a pump. Can't remember how often to lube. There were some other zerks that needed to be greased in the baler head area, but not a lot.
/ JD baler lube system question #4
Which baler?
The new 468 round baler have a luber that lubes when the gate opens. I am told it way over lubes stuff.
D.
Their line of small sq balers
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2022 EZ-GO ELITE...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
