JD B and L306 mower?
   / JD B and L306 mower? #1
DS DEERE
I have about 5.5 acres of thick pasture grass and am looking at purchasing a L306 Woods mower with a John Deere B. Does anyone have experience using either/both of these. What is reasonable to spend on this?
   / JD B and L306 mower? #2
That is a Woods finish mower model isn't it? Some might have difficulty with operating the clutch but if the field is open you only need to get nervous around the edges!
   / JD B and L306 mower? #3
The deere does not have a live PTO. The PTO will stop when you pull the clutch back. Like said, will be ok out in the open but if you hit a heavy spot there could be problems.
It will work once you learn the tricks.
Dan
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
