JD B and L306 mower?
   / JD B and L306 mower? #1
DS DEERE
I have about 5.5 acres of thick pasture grass and am looking at purchasing a L306 Woods mower with a John Deere B. Does anyone have experience using either/both of these. What is reasonable to spend on this?
   / JD B and L306 mower? #2
That is a Woods finish mower model isn't it? Some might have difficulty with operating the clutch but if the field is open you only need to get nervous around the edges!
   / JD B and L306 mower? #3
The deere does not have a live PTO. The PTO will stop when you pull the clutch back. Like said, will be ok out in the open but if you hit a heavy spot there could be problems.
It will work once you learn the tricks.
Dan
Two Honda Engines (A50325)
Two Honda Engines...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
2005 TRANSCRAFT 48 X 102 FLATBED (A52472)
2005 TRANSCRAFT 48...
