JD 955
   / JD 955 #11
JD955, that's a nice machine...I have had several.
If the backhoe is not leaking down visibly and the leaks are
internal (valve or piston), I would leave it alone. Use the
transport lock to keep the boom up when using the tractor for
other work. If it takes an hour to drop to the gound, that is
not that bad. If the fluid is hot, it will leak down faster.
Personally, I tend to not use my hoe's boom lock, because then
I forget it is engaged and have to get off to disengage. I don't
drive my main tractor with hoe very long distances, but I do
periodically reach around and raise the boom to keep it from dragging.
I lower the boom to the ground whenever I park the tractor.
   / JD 955
I had the dealer look up to see when the last time they changed the hydraulic oil because my uncle it to the dealer for repairs and service. Last changed was back in 2004.
Sorry for the newbie questions but I have to ask. It's ok to change the oil with the backhoe on right, as long as all the pistons are closed?
   / JD 955 #13
Don't be sorry, that is how we ALL learn:D
Having the BH on is absolutely OK when changing the oil.
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2006 Ford F-650 24ft Flatbed Truck (A55788)
2006 Ford F-650...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Fiat 250 Montagna Tractor (RIDE AND DRIVE) (A50775)
Fiat 250 Montagna...
