JD 955 Headlights kill motor
   / JD 955 Headlights kill motor #1
croasdale
White Stone, VA
John Deere 955
Any idea why turning on the headlights would cause the engine to quit on my 955? I bought it with the headlights not working and found the fuse pulled. Replaced fuse and cleaned some connections and the lights work fine as long as the motor's not running.:confused:
   / JD 955 Headlights kill motor #2
I think the only electrical thing that would affect a diesel motor after it is started is the fuel cutoff solenoid. Does the 955 shutoff with the key?
   / JD 955 Headlights kill motor #3
There was a thread here very recently involving exactly that problem. The culprit was a bad battery (had a shorted cell). The battery apparently couldn't hold the fuel shutoff solenoid open when the headlights were turned on.
Thanks,
I thought it might be the battery getting weak since I don't recall it doing that when I first fixed the lights a few months ago. The tractor frequently sits a month or two between uses.
I'll try a new battery to see if that does the trick.
Ed
   / JD 955 Headlights kill motor #5
I have a 755 that died when lights were turned on. It was a corroded contact on the key ignition switch. It evetuallly burned out leaving the tractor totally dead.
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
FAKE (A52472)
FAKE (A52472)
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
