JD 950 transmission too hot?
   / JD 950 transmission too hot? #1
jsec
Murrysville, PA
Kubota B21
I bought a circa 1980 JD 950 with manual transmission that I use to mow pasture with a 5 foot rotary cutter. After mowing for awhile the transmission housing gets so hot I can't hold my hand on it. This doesn't seem normal. The hydraulic resevior is full and the fluid is clear. What could be the cause?
   / JD 950 transmission too hot? #2
My 1050 does the same thing... has since '87 when we got it...
As long as the light on the dash isn't on and the radiator/grills are clear, I just watch it when wearing shorts. Gets a might hot on the lower legs if you bump it. /forums/images/graemlins/tongue.gif
   / JD 950 transmission too hot? #3
Its normal for the transmission housings to get to hot to hold your hand on.
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
