JD 950 transmission too hot?
   / JD 950 transmission too hot? #1
jsec
Murrysville, PA
Kubota B21
I bought a circa 1980 JD 950 with manual transmission that I use to mow pasture with a 5 foot rotary cutter. After mowing for awhile the transmission housing gets so hot I can't hold my hand on it. This doesn't seem normal. The hydraulic resevior is full and the fluid is clear. What could be the cause?
   / JD 950 transmission too hot? #2
My 1050 does the same thing... has since '87 when we got it...
As long as the light on the dash isn't on and the radiator/grills are clear, I just watch it when wearing shorts. Gets a might hot on the lower legs if you bump it. /forums/images/graemlins/tongue.gif
   / JD 950 transmission too hot? #3
Its normal for the transmission housings to get to hot to hold your hand on.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
POWER LINE 180 LOT NUMBER 89 (A53084)
POWER LINE 180 LOT...
New Long Forks (A53002)
New Long Forks...
