JD 950 tractor wiring diagram request.
   / JD 950 tractor wiring diagram request. #1
Shogan6205
Candia NH
Cub Cadet
Am working on my recently widowed neighbor tractor. Will not start, new battery installed. Appears starter control circuit at fault. Wiring diagram will facilitate troubleshooting problem. Suspect open circuit in wiring harness, (rodent)?
This a nice little tractor with Fel & back hoe only 1200hrs.
   / JD 950 tractor wiring diagram request. #2
Link to download manual w/ wiring on the way in a moment, hope it helps
Joe
   / JD 950 tractor wiring diagram request. #3
Might want to check the safety cut out switches first before doing anything, could be that simple. Make sure the PTO is not engaged, you are sitting on the seat, ( seat switch ) and there is one more on the right side of your seat when you are seated if I remember correctly. If it still doesn't start, you have a good battery, you can jump from the battery + on the starter to the solenoid and it should crank. I'd post the diagram, but the service manual went with the tractor when I sold it.
Chris
Thanks to all those that responded. I received all the information needed and more. What a great resource!
Thanks again.
Steve
   / JD 950 tractor wiring diagram request. #6
Joe
Can anyone send me the wiring diagram for the JD 950. It would be greatly appreciated since I have had some rodents chewing the wires
   / JD 950 tractor wiring diagram request. #7
pqhbv
:welcome: to TBN
Send a private message (PM) to joecdeere (see reply #2 above) as he maybe can help you out.
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
KUBOTA M7-132 (A53084)
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
