JD 950 fuel in oil
   / JD 950 fuel in oil #1
learjet24
JD 950
Hello everyone, i recently picked up a 950. drove and ran nice, no smoke etc. however when i got it home and started using it the oil pressure light came on when idling after mowing for 45 mins. i had just changed the oil with Rotella Diesel 15w40 and a non JD filter before i started mowing. Got the needed adapter and plumbed in a mechanical pressure guage. 60 psi cold, but dropped to 20 after 30 mins or so at 2200 rpm. at idle was about 10psi. Let it cool, then drove back to the barn. Ordered a oil analysis kit im still waiting on. was reading up on bearing replacement and engine overhauls while im waiting for the oil analysis kit and found a few posts about fuel getting in the oil. went up today (tractor has set for a week) and the crankcase is way over full, and i believe i smell diesel fuel in the oil. Still will do the analysi, but wondering what problems with the 950 specifically might allow fuel to get to the oil. Looks like either fuel pump or injectors from what ive read. im leaning towards the pump atm as theres no smoke at startup or any time ive run it.
i did find this old post i found interesting, i plan to torque the delivery fittings next, and if any seem loose change the oil and run it w the gauge installed again.
https://forums.yesterdaystractors.com/threads/fuel-in-oil.1039297/
any other ideas or easy things to check?
much appreciated!
checked the delivery fittings, 2 were loose. retorqued, changed oil, mowed for over an hour. oil pressure now 40 at rated rpm, 20 at idle. ill live w that
thx pumpguysc!
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
