JD 8640 hydraulic problems
/ JD 8640 hydraulic problems #1
xx507xx
Michigan
Jd 8640 white 2-135 case 2470 IH 1466 and some others
hey guys need some help i have an 8640 that lost all hydraulics i have checked the two screens on the back half they were clean and the coupler from the engine to pump is good i have no steering or remotes
thanks Errol
/ JD 8640 hydraulic problems #2
If equipped with a pto, does it work? Is the trans hydraulic circuit maintaining 165psi? Could be a failed trans pump or trans pump drive. On occasion the pressure relief or the plugged filter divert valve will stick with a wee bit of dirt or a broken spring. No oil from the transmission hydraulics pumped up to the front pump inlet means no high pressure hydraulics.
pto works. i will check thoues out 2marrow thanks
/ JD 8640 hydraulic problems #4
Non functioning stroke control valve in main hyd pump will stop hyds from working
/ JD 8640 hydraulic problems #5
xx507xx - did you solve your problem withe the hydraulics of your 8640. I am have the same problems with the dydraulics and steering.
/ JD 8640 hydraulic problems #6
Check hyd pump drive to be sure it's not stripped/slipping.
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2022 EZ-GO ELITE...
Shell Gas Pumps Yard Art (A64557)
Shell Gas Pumps...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
