JD 8640 hydraulic problems
/ JD 8640 hydraulic problems #1
xx507xx
Michigan
Jd 8640 white 2-135 case 2470 IH 1466 and some others
hey guys need some help i have an 8640 that lost all hydraulics i have checked the two screens on the back half they were clean and the coupler from the engine to pump is good i have no steering or remotes
thanks Errol
/ JD 8640 hydraulic problems #2
If equipped with a pto, does it work? Is the trans hydraulic circuit maintaining 165psi? Could be a failed trans pump or trans pump drive. On occasion the pressure relief or the plugged filter divert valve will stick with a wee bit of dirt or a broken spring. No oil from the transmission hydraulics pumped up to the front pump inlet means no high pressure hydraulics.
pto works. i will check thoues out 2marrow thanks
/ JD 8640 hydraulic problems #4
Non functioning stroke control valve in main hyd pump will stop hyds from working
/ JD 8640 hydraulic problems #5
xx507xx - did you solve your problem withe the hydraulics of your 8640. I am have the same problems with the dydraulics and steering.
/ JD 8640 hydraulic problems #6
Check hyd pump drive to be sure it's not stripped/slipping.
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
2018 GENERAC MOBILE PRODUCTS MTL6S (A68842)
2018 GENERAC...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Front Tank Bracket (A64126)
Front Tank Bracket...
