jd 855 loose front final hubs
   / jd 855 loose front final hubs #11
Thanks for the heads up. I have also been fretting over what sounds almost like knocking in the engine. I never had a diesel anything before. I found a couple youtube vids and I don't think I have anything to worry about. One guy called it the " Yamer Hammer" I am going to go over the valve lash tough since I doubt it has ever been done. Then I think just do the maintenance and run it!
Kimodc
Thank you for your input
I think that you just saved me $400 thanks
I was really going to look into replacing the aluminum hub housings (as per local jd dealer recommended ) but if you have replaced them on your 955 and little to no difference in the play I think it is safe to say it is just bad design flaw from jd I replace almost every bearing and seal in my final drives
They still had slope in them when I was finished
I think I am just going to keep an eye on them and make sure they don't get
Worse
Thanks again
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
BigTex Dump Trailer (A56858)
BigTex Dump...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
