JD 855 fuel prime and leak issue
   / JD 855 fuel prime and leak issue #1
bayfarm
Sugar Grove, IL
JD 3020 JD 855
Need some help with fuel issue on JD 855. Fuel system kept losing prime. Discovered fuel in crankcase oil. After tractor sat a few hours all fuel siphoned into crankcase. (Has a mechanical fuel pump on this model) I had suggestion that bad fuel pump was allowing fuel to pass into crankcase??? Other than part swapping, any other suggestions for tracking down reason? Many thanks in advance.
   / JD 855 fuel prime and leak issue #2
Usually it is the mechanical diaphragm fuel lift pump that is allowing fuel into the crank case. You can either replace the pump or cap that spot off and install an electric fuel lift pump. With the electric conversion you would never get fuel in the crank case from the lift pump again.
Hope this helps!!
Thanks, that was the direction I was working towards. I removed pump. I opened fuel pump and added a small puddle of water. When activating the pump by hand, water did flow out of the plunger end. The plunger would be inside the injector pump and allow fuel to enter oil. This machine has MANY hours on it so will probably go with new pump and hope it will fix the problem.
   / JD 855 fuel prime and leak issue #4
Replacing the pump will be the easiest way to go. If you are still getting fuel into the crank case, after the lift pump replacement, then there is likely a problem with the injection pump. Here's hoping that's not the case!!
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
