JD 855 fuel prime and leak issue
/ JD 855 fuel prime and leak issue #1
bayfarm
Sugar Grove, IL
JD 3020 JD 855
Need some help with fuel issue on JD 855. Fuel system kept losing prime. Discovered fuel in crankcase oil. After tractor sat a few hours all fuel siphoned into crankcase. (Has a mechanical fuel pump on this model) I had suggestion that bad fuel pump was allowing fuel to pass into crankcase??? Other than part swapping, any other suggestions for tracking down reason? Many thanks in advance.
/ JD 855 fuel prime and leak issue #2
Usually it is the mechanical diaphragm fuel lift pump that is allowing fuel into the crank case. You can either replace the pump or cap that spot off and install an electric fuel lift pump. With the electric conversion you would never get fuel in the crank case from the lift pump again.
Hope this helps!!
Thanks, that was the direction I was working towards. I removed pump. I opened fuel pump and added a small puddle of water. When activating the pump by hand, water did flow out of the plunger end. The plunger would be inside the injector pump and allow fuel to enter oil. This machine has MANY hours on it so will probably go with new pump and hope it will fix the problem.
/ JD 855 fuel prime and leak issue #4
Replacing the pump will be the easiest way to go. If you are still getting fuel into the crank case, after the lift pump replacement, then there is likely a problem with the injection pump. Here's hoping that's not the case!!
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 LAREDO 5TH WHEEL (A60736)
2007 LAREDO 5TH...
